TwinTurbo.NET: Nissan 300ZX forum - Re: Second. No spark, even after changing to firing coils
Subject Re: Second. No spark, even after changing to firing coils
Posted by surferkidusa on January 07, 2011 at 2:30 PM
  This message has been viewed 87 times.
In Reply To Second. No spark, even after changing to firing coils posted by CoHPhasor on January 05, 2011 at 06:32 PM
Message i already switched PTU's and the subharness, no change. i guess my next step is continuity. could it also be a continuity issue between the ptu and the ECU making it an EFI harness problem?
:means there is a problem with the connections most likely.
check all the PTU connections for corrosion.
:If you have an old style PTU (has metal heatsink for a face) change it out.
Beyond that, measure the resistance between the PTU connector and the coils not firing, then check the resistance between firing coils and the PTU.
You could have a short/broken wire between the PTU and coils.
:(IF the connectors check out.)
Switching out to a known good PTU will be useful as well.
